Hi guys. Just wondering in connection with deciding the timber to use on my workbench project what hard maple is like to buy and work in larger sections?
I've ripped and planed lighter strip for a friend out of rough sawn material, and it seemed absolutely fine. The books seem to think so too, but on the other hand this piece sounds a bit worrying: http://www.thewoodbox.com/data/wood/mapleinfo.htm I don't want to pay out a lot for it and make a bags of it.
I've 4 hp Hammer machines, everything will be nice and sharp and i plan to buy a 40T or so rip blade. I'm well set up with Bessey parallel and other clamps, although i've never glued up anything of this sort of size before.
The bench looks like coming out of about 2 in rough sawn material which would need to plane clean at 1 5/8+ for the 5 in sq laminated legs, and the 4 in wide laminations (edge on) to be glued up for the tops. Also for the stretchers.
I guess the questions that come to mind are what widths it tend to come in at 2 in rough sawn kiln dried 1st quality, can i expect to get at least 1 5/8 thickness planed up out of this 2 in stock, and is it hard to work - does it glue, plane, drill, mortice and finish relatively painlessly?
What to avoid and look out for when buying? Is cupping upon machining likely to be an issue, and does it equilibriate quickly - i'd be hoping to start work after giving it about a month in the shop after buying.
It seems to be commonly used for workbenches. Chris Schwarz himself uses yellow pine on the basis that despite dinging a bit easier it has good stiffness and other properties for this sort of use, and is much cheaper in the US. Chances are it's more expensive here, but you never know.
Thoughts anybody?
ian
Thoughts anybody?
ian
