Neomorph
I was just working out a levelling jig plan for reducing thin material (what I'm aiming at is creating 1mm thick glazing plastic out of 3mm to create shims) when I had a thought about what someone else here said about MDF.
Currently my temporary workbench top is laminated MDF (2x18mm) and I was going to use the levelling jig in the future to re-level it when it gets dinged up. Obviously this isn't correct after finding out that MDF has a hard outer layer and a "fluffier" inner layer.
So what's the solution? Some people here have mentioned using plywood. Is this the correct way to go? Add a Plywood top to my 36mm of MDF? What thickness would you suggest? I've got to get this sorted as in a few weeks time as my winter "pain barrier" is going to drop and I can finally get on and do stuff I've been waiting to do in my shed (namely clearing out the rubbish and finally getting around to start building my workshop).
So what do you guys suggest?
