PaulO
Here are a couple of drawings of a workbench I am planning on building. It is a simplified Charlesworth pattern bench, intended to be made from 3" stock.
The top is 4" thick, and I intend to use crown cut beech laminated to make a quartersawn top for maximum stability.
The bench height is 40 1/2" but I may reduce it by an inch. I have used a 40 1/2" bench and I found it comfortable.
At the moment I have only shown one vice, but I am toying with the idea of fitting a tail vice (and more dog holes)
I have opted for the more traditional square dog holes, so I'd like to get their placement right before the top is constructed.
The way I work with my current bench, I have never needed lots of dog holes or a tail vice, so I remain undecided. The sliding tool well means you can easily place an F clamp for added work holding.
The wedged through M&T is just for aesthetics, as all the M&T are draw bored.
The sliding tool well will probably be made in several sections, so that an anglepoise can be accommodated, as well as my growing chisel selection.
I can e-mail the sketchup file to anyone who is interested (around 300k with a simplified vice model).
Based on this drawing it would weigh 150kg (330lbs in old money) so it shouldn't blow away in a breeze.
Anyone have any thoughts / suggestions?
