transatlantic
Boom!
In the picture below, we see a tenon being cut with it clamped in a vice between the faces of the board. By clamping it this way, you are then able to rotate either towards you, or away from you, enabling you to see your lines better.
I was wondering what would be the best way of achieving the same thing, but without a vice? just clamp a board to the bench, and then use an f clamp to clamp the work piece to that board?
I do actually have a front facing vice, but annoyingly, it is situated at the end of the bench, next to a wall. So you can't (comfortably) get to the side of it. And the other end of the bench has storage next to it.
![99933244-hand-cut-tenons_07.jpg](https://proxy.imagearchive.com/e4c/e4c32fcc5cbb3e4b58d6ccf8b8813d56.jpg)
