Good day
When I'm planning the dimensions of a project, I normally write the measurements in Centimeters, like 54.0 or 85.3, because that's what I read on the measuring tape or the ruler (and also for my wife to understand it).
But I noticed that the woodworking measurements are in Millimeters.
A length of 153.6 cm is very easy to see on the measuring tape while 1536 mm is forcing me to thing for a second what or how I have to read it on the measuring tape or ruler, of course, I just have to put the dot (in my mind) before the 6, but then, why not to put it there at the first place.
I worked in aviation for 36 years and I remember that we had to change many placards of switches, selectors and lights to reflect exactly what they mean, for example, an Anti-icing switch was placarded as "Open" or "Close" and not like before "ON" or "Off".
I think, that if you will tell your client that the unit will be 3565 mm long and 2005mm high, he will tilt his head (to consentrate all the IQ in one place) with a question mark on his face.
So what is the reason for the measurements to be in mm if the ruler reads in cm.
Regards
niki
Regards
niki
