Wooden railway sleeper ID please
nxf
New member
22 Jun 2020
Caerwys
I have built a wooden walk way in my garden from railway sleepers that were left by previous owner. The house is situated next to a disused railway line (1960s) in North Wales so possible they were scavenged many years ago or sourced elsewhere?
I needed to plane the top edges which were quite hard and noticed a distinct dark and light colour.
Does anyone have a clue of what wood this is?
If they are genuine old railway sleepers they are pressure treated to preserve them, e.g. with creosote, this may enhance the contrast of the grain; they can be hardwood or softwood, impossible to tell from the picture. I would not plane them personally, as the surface is gets impregnated with grit from the track ballast.
Thank you, that explains why I was sharpening every 1/2 hour, so will not be as quick to plane them again. They were all used on a railway as had metal numbers, fixing holes and recessed bits with horsehair? matting, I guess used as a shock absorber?
I finished it a few years ago, so access to the cabin is a lot easier now. I used s/s screws, treated 44mm decking so hope it will last a few years.
There are loads of woods that have been used for railways sleepers - basically, if it met the spec and was the cheapest timber available at the time, in it went....
Looks like Scandinavian Pine sleeper. Used as a secondary line or siding sleeper. not a main line one.
If it is covered in pitch it will be a pain, with correct PPE warm it up and scrape it off. That way the impeded grit will come off.
If it is just think with bitumen, do the same.
Then with a sand clean up. You will burn through a lot of sand paper.
Petrol can be used to thin out the creosote, but it is up to you.
Many thanks, I followed up your Scandinavian Pine suggestion and after a lot of research found out that was indeed one of the timbers used in the past.
