I want to have a go at making some wooden hinges. I have found a great set of plans, that look like just what i want to achieve. They are Australian, though and so the timber suggestions are either unobtainable (easily) or very expensive (ie not good for a first attempt)
The author suggests "Timbers I have used successfully for these hinges include: Ebony, Hornbeam, Satin Box, Jarrah and Rosewood. I have used softer timbers like Red Cedar and Mahogany successfully, but they may not wear as well as the harder timbers. Thickness your wood to 6 mm, trying to get as clean a finish as possible on both sides." as well as saying that it should be quarter sawn.
Any suggestions for anything native or easily sourcable that is reasonably hard, straight grained, close grained, resistant to splitting as soon as you look at it etc? Ideally a light and a dark timber, but that might be stretching the request a bit.
I have a bandsaw to take slices off "normal" sized boards, so the 6mm element isnt important for the sourcing!
