Kalimna
- Joined
- 18 Nov 2009
- Messages
- 1,275
- Reaction score
- 2
Greetings folks,
Having has a wee bit of success with a pair of electric guitars last year, I have moved on to attempting a purely acoustic instrument. The end goal is to produce acoustic guitars, but I wanted to build something for my two boys, and figured that ukuleles would be more manageable (and certainly cheaper on materials) and a more appropriate size for a 3 1/2 and 1 1/2 year olds....
Anyway, sometime in April last year, I started milling up some pieces of ripply maple, afromosia, spruce and ebony to make a pair of concert ukuleles. Plans I purchased online from Georgia Luthier Supplies, and beyond the timber (excepting the ebony which had been purchased as a guitar fingerboard, now split into two fb's) which was essentially scraps, I only had to buy tuners, fretwire and strings.
The maple has quite a tight ripple to it, and may not have been the best choice as a starting project, but as with my two previous stringed efforts, the whole process so far has been one of learning, figuring out processes, d'oh moments, ahhhh buggerit moments and pleasure when something works.
Information on how to build acoustically has been absorbed from Cumpiano & Natelson, Hiscock, Obrien online tuts, and a few other internet resources. As in many aspects of woodworking, there are many ways to successfully skin a cat, and mine has been an amalgamation of many ideas. However, and unlike most current practice, I opted for free-form building (as per Cumpiano & Natelsons' bible on the subject) rather than go to the extra expense and effort (of both time and space) of building an outside mold. This has presented with a few particular issues, notably verticality of sides and absolute adherence to outline shape, but neither of these should prevent a workable instrument from being produced. And as I am in no particular rush to get them finished, production-run efficiency is not an issue. A further detour from normality has me using a butt-joint for the neck-body join, but more of that later.
So, before I begin with the photos, here is a breakdown of the two ukes.
A final note is that the photos may be from either build, but I shall try and keep them separate.
model - concert
scale - 15" (fretting template from Stew-Mac)
back & sides - ripply maple
soundboard - spruce offcut from archtop guitar wedges
neck - ripply maple for one, afromosia (ex laboratory worktop) for the other
fingerboard - ebony
binding - indian rosewood offcuts from acoustic guitar set
end wedge - padouk
bridge - padouk
finish - not decided, maybe a first stab at french polishing
First piccy, jointing the edges of the soundboard prior to glue up. Notice the wobbly, relatively wide grain.
Soundboard glued up thicknessed
Soundhole decoration channel trial run in some BnQ ply using trusty dremel and spiral bit. The soundhole itself is cut out using the same method, only routing a little deeper.
More routing. Despite the 'cheap and nastiness' of the dremel circle-cutting jig, it does work nicely, though difficult to fine tune. A suitably sized hole is pilot-drilled into both the soundboard and workboard underneath. This then accepts the 'spike' on the jig, about which the router rotates.
Decorative strips inlaid and trimmed (much kudos to anyone who can ID the timber the plane is made from
Skipping ahead a wee bit, here are some of the soundboard braces being glued on. Unlike most modern acoustic guitars, it seems that ukes still have a flat top so the braces are straight pieces of spruce. Those adorning the back do have a radius routed onto their gluing edge to induce a slight curve to the back. Again, in a break from more modern teachings, I am using cam-clamps rather than a go-bar deck to clamp up the glueing. Even though these wooden clamps are relatively lightweight, there is still plenty of mass to induce an unpleasant twisting of the soundboard if inadvisedly handled.....
Here are both soundboards fully braced (though not carved yet), with an indian rosewood bridge patch. As to the bracing pattern - a little bit from the plans, a little imagination.
Right then, onto the neck. As with the previous guitar builds, i opted for a scarf joint to enable both a stronger headstock, and a more efficient use of the timber. I think i used two pieces of maple for the neck, however, hence the odd position of the sawcut. Previously i had used a bandsaw for this, rather important, cut but went for a handsaw this time.
Two new necks, cut surfaces handplaned (I still find it odd that some American luthiers will take the wood straight from a tablesaw cut and glue up without handplaning this critical joint) and awaiting glue up.
Glueing up the scarf joints. Note the unusual use of dining table and Warburtons bread wrapper. Unfortunately there was a little slippage of the scarf when clamps released, but nothing that cant be tidied up.
Right then, more to follow on the next post.
model - concert
fingerboard - ebony
end wedge - padouk
bridge - padouk
![IMG_0445.jpg IMG_0445.jpg](https://cdn.imagearchive.com/ukworkshop/data/attach/16/16112-IMG-0445.jpg)
![IMG_0513.jpg IMG_0513.jpg](https://cdn.imagearchive.com/ukworkshop/data/attach/16/16113-IMG-0513.jpg)
![IMG_0515.jpg IMG_0515.jpg](https://cdn.imagearchive.com/ukworkshop/data/attach/16/16114-IMG-0515.jpg)
![IMG_0536.jpg IMG_0536.jpg](https://cdn.imagearchive.com/ukworkshop/data/attach/16/16115-IMG-0536.jpg)
![IMG_0535.jpg IMG_0535.jpg](https://cdn.imagearchive.com/ukworkshop/data/attach/16/16116-IMG-0535.jpg)
![IMG_0545.jpg IMG_0545.jpg](https://cdn.imagearchive.com/ukworkshop/data/attach/16/16117-IMG-0545.jpg)
![IMG_0563.jpg IMG_0563.jpg](https://cdn.imagearchive.com/ukworkshop/data/attach/16/16118-IMG-0563.jpg)
![IMG_0522.jpg IMG_0522.jpg](https://cdn.imagearchive.com/ukworkshop/data/attach/16/16119-IMG-0522.jpg)
![IMG_0532.jpg IMG_0532.jpg](https://cdn.imagearchive.com/ukworkshop/data/attach/16/16120-IMG-0532.jpg)
![IMG_0639.jpg IMG_0639.jpg](https://cdn.imagearchive.com/ukworkshop/data/attach/16/16121-IMG-0639.jpg)
