I'm looking to solve my wood storage problems. An extensive google on the subject has turned up a couple of ideas that should work nicely. However...
Many of the US designs employ black pipe (or galvanized pipe) set into drilled timber. There's one bit of my space-challenged workshop where this would be a great solution but I'm having trouble tracking down suitable pipe. Since the UK has switched almost-exclusively to PVC and copper piping, iron pipe of any description seems to have disappeared. A visit to the local DIY outlets turned up nothing but some lengths of 16mm tubular steel. 16mm is the outside diameter but the tube walls seem a bit on the thin side.
Anyone with an engineering bent able to say whether that would be a suitable substitute? Or anyone have any ideas as to a supplier of an appropriate material? (I know that pipe clamp fittings are available here without pipe, suggesting that it should be available from somewhere!)
Pete with no room to work
