Wood glue open time
13 Jul 2015
Wales
I was watching an 'askwoodman' video on YouTube and he mentioned the idea of keeping your wood glue in the fridge to give you a longer open time. Simple idea! I wonder how much of a difference it would make, ... 10 minutes extra?
Also, an excuse for a workshop mini fridge, which coincidently has space for a few beers :)
Sent from my SM-J510FN using Tapatalk
The more beer, the longer it takes to open the door to get more beer.
I've just started using titebond 111 due to the heat drying out the bison glue i normally use.
Huge difference in the setting time. Put the titebond in the fridge and it would take a week to cure.
If you fridge is below 5C (which it should be) that's too cold for curing properly according to the PVA I use...
Sent from my MI 3W using Tapatalk
Sure - but you wouldn't be leaving the piece to dry in the fridge. It would warm up to room temperature ....
phil.p":uktxgpg0 said:
I did try getting my sideboard into the fridge ... :D
With PVA or PU you can damp or even quickly wet the surfaces to give youy a bit more time in very hot, dry weather.
I've found pu and water have the opposite effect. I usually give the surfaces a quick wipe if I want the glue to cure quicker.
I thought this too! go home Phil, you're drunk!
I tried the water spray trick to delay curing......., nope.
I accept i have a lot more heat than you guys, but the water spray added seconds at best.
Titebond "Extend" has a longer (I've no idea exactly how much longer mind you) open time than regular Titebond. I keep a bottle handy for beer fueled glue ups ;)
Sent from my Nexus 6P using Tapatalk
by like a few minutes :p
Sorry. Yes it sets it, but I find the joints slide together a bit easier though. Wouldn't work of course with multiple joints.
I've just this minute come in from gluing up a set of blanks for my next box.
Alternating walnut and rosewood, 6 squares in all.
Laid them all in a line and spread titebond three all over 5 surfaces 7" x 12", had time to spread the glue all over, slap them together, put them in the big vice, align one side with a square, and then tighten using the vice and seven clamps along the top edge.
No problem at all.
Oh, the temp in the garage is 38c (100.4f)
no way could I have done all that with the other glue. i know because I've tried it in the past. with or without water spray.
Titebond 111 does it for me.
Now its time for me to cool off.
