Paul200
For various reasons we want to install a door in the opening to the extension on the back of our cottage.
I'll explain the problem - this was the original back door of the old part of the house, the wall is two feet deep and built of stone - and also out of true! The doorway will need to be built to the left side of the opening with the rest stud and plasterboard.
I've put two strings from corner to corner diagonally and everything is in the same plane. Apart from the fact that the wall to the left is about 2 inches further into the room than the wall to the right :? As far as I can see there are just two solutions - one is to just follow the line of the walls ((diagram 1) and put up with the tiles on the far side looking awful. The other (diagram 2) is to build the studwork on the same plane as the right hand wall and have a 2" recess where it meets the left side, keeping everything square (ish).
I'm not at all sure which method I prefer but just wondered what others would do - or even if there is another solution.
Can anyone help please?
