Which mandrel saver to buy?
ScouseKev
29 Jun 2011
South Liverpool
I'm new to turning and just looking to get a setup for turning pens.
I'd like to buy a mandrel saver and was wondering which one.
The Axminster evolution is £41.00.
Turners workshop is £29.99 for just the saver.
Penkits uk do one for £18.00 plus another £14.00 for the mandrel.
The planet support is £28.00.
Does anyone have any experience of the 4 above.?
Any advice welcome and thanks in advance. Kev
Some savers have different sized holes so you will need to match them. I won a Axminster saver as a prize but the hole was too small for my mandrel, so it will depend on who's mandrel you have. Unfortunately they is no standard between manufacturers and even the bushes/bushings can have different sized centre holes. Most times I turn pens I turn between centres rather than set up the mandrel.
I use a hollow live centre, and turned a delrin insert for the end. i have the planet mandrel, but I am not sure whether it is any different to any of the others. Seems good quality though.
The axi is cheaper than you state isnt it? http://www.axminster.co.uk/axminster-ev ... e-ax938693
but dalboy gives a warning, so less risky to buy both parts together.
I have the planet mandrel and recently got the saver from the turnersworkshop. It's nice bit of kit.
Dalboy":2tt656gf said:
I won a Axminster saver as a prize but the hole was too small for my mandrel.
That's not a problem, just drill or ream out the saver to fit the mandrel. Being too big on the other hand is a problem!
I can understand why some manufacturers make large and small mandrels but you'd think it would be in everyone's interest for them to be of a common specification. :wink:
woodpig":gvvulasp said:
Think the initial problems arise from Imperial (older UK & USA market) and Metric, I would not dream of suggesting that a brand would attempt to keep users tied to their particular system. :roll:
I just turned up a brass bush to fit into my hollow interchangeable tip live centre, easily done on a wood lathe using a pen mandrel.
That is also another factor for the different sizes
That is what I used until I won my saver
What do you think I did yes I drilled it out not that it needed much. But I would rather people know about the problems and better still buy a matching pair is better than having to modify something.
As for your second comment a common specification would be a great thing but manufacturers will not want to change all of their tooling so they were all the same
There wouldn't be a need to change any tooling, mandrels are centreless ground. :wink:
