Keith,
It's not a bad offer, is it? I have the Delta one that looks just like it, but I don't know what the differences are. Probably none, except I ended up paying more
I'm very happy with mine. Good capacity and I like the variable speed. It's had good reviews too. I avoided the Record ones as I was advised that the solid cast beds would be better for lessening the vibration. Also, I didn't like the idea of having to change speed using the belt; the lever is much easier.
Just as a guide, here's what I ended up buying within a month of getting the lathe:
Woodturning; a foundation course by Keith Rowley
Axminster Cone friction drive (Good for the beginner 'cos when you "catch" it allows the workpiece to stop rather than flinging the tool across the workshop like a pronged centre does. You're probably a better turner than I, and won't need it :wink: )
Drill chuck (essential IMO. Good for holding workpieces too)
Peter Child Screw chuck (excellent. Well worth the money)
Friction Polish (I use Speed'n'Eeze and it lasts for ages)
Sanding sealer
Sanding disk system (I forget which one)
Liberon Woodturner's Stick
Subsequently I've only added a couple of tools to that. A fancy chuck would be nice, but I don't turn enough to justify it. I think the book and the drill chuck are my two "must haves". You'll also want a full face visor and a dust mask. Gosh, it all adds up doesn't it? :roll: If you really get the bug, you'll probably end up spending a fortune :wink:
Hope this is of help.
Cheers, Jester
Jester's Court
