Ed Bray
When I cleared out my garage about 20 years ago, I took down some roughsawn (band-saw marks both sides and one Waney edge) planks that had been being used as shelving. They have been at the back of the garage since that time and as I was looking for some wood to make another scroll saw puzzle for my grandson I thought I would see what lay under the grime and band-saw marks.
The largest plank was about 14" wide by 6ft long and just under 23mm thick. I cut off a bit large enough for my project (crosscut and squared up waney edge on the table saw) and hand planed both sides, initially with my scrub plane to get the surface uniform and then use my Veritas 4 1/2 to clean up the boards on both sides.
The wood is relatively soft in comparison to other hardwoods I have used (Oak, Iroko, Mahogany) but seems harder than pine. The wood planes nicely with the grain and leaves a beautiful silky smooth finish, but against the grain and when going through the table saw (in any direction) the finish leaves a lot to be desired. The wood also gives off a sweet almost fruity smell (can't describe it but nothing like pine) and is very dry (well it has been in a dry garage for decades).
The first image shows the back side of the wood and shows some tearout around areas of differing grain, as well as the shiny finish from a very thin cut with the plane. Second image shows the reason for the funny shape.
The dolphin is about 11" long and 6" wide and the board ended up 17mm thick.
