Using the table saw to cut up a panel today, nothing fancy just a piece of white MFC for a kitchen cupboard shelf. Didn't need to be super accurate but I am taking every opportunity to practice using the new saw.
Wanting to avoid chipout I put masking tape over my cut lines which worked nicely (although ultimately I found out the sharp new blade would have been fine without the tape).
What I didn't understand though was why my cuts were not coming out square despite all the care I had gone to setting up the fence on the sliding table.
I checked my combi square was actually square, it was acceptable, I checked the sliding table again, it was also good. There is a tiny bit of play in the fence, but holding work against it pulls that out so that wasn't it. Then it hit me, the tape! 1 and sometimes 2 layers of tape on the edge were pushing the work out away from the fence and skewing my cut.
I removed the tape, made a new cut and the results were vastly improved. I went from 2mm out over 300mm to less than 0.5mm. Still not perfect but much better. Shows that just the thickness of a piece of masking tape can make a big difference on a long cut.
