Wenge White Wip
JonnyD
10 Mar 2008
Lincolnshire
A little project I am just starting which may be of interest. I have already cut up a load of 25mm mrmdf which will become the shelving unit. There's a few mitre joins in this and the mitres have been cut on the panel saw and then jointed with dominoes
A 3mm round is put on the inside edges as it will be impossible to do after its assembled
I made up some cramping blocks by doing 2 45 degree saw cuts in some cls timber these are clamped onto the mdf shelves
The cramping blocks then allow the mitres to be pulled up nicely with pressure across the mitre
Some bits that have been assembled so far
When its done it should look a bit like this . There's some big scribes to the wall and some led lighting around the edges
Thanks for looking
Jon
i like the idea of the clamping blocks- much better than the band clamps i have tried to use on boxes.
Today's instalment started on the Carcases and realised I had made a mistake with the length of the sides . I had not added on the thickness of the top and bottom so the solution was to turn the sides around so the holes I had already dominoed were on the outside and make some new bottoms and tops that the sides sit onto. The mistake can be seen here but won't be seen after installation
The Carcases were marked out for the dividers
A simple fence clamped on to guide the domino
The domino slots are off centre on the 25mm mdf cause its easier to mark a everything out with the 10mm offset on the machine
Just a case them assembling everything to see how it looks got 2 of the top carcases done
Got the veneer out to see what it looks like nicely quarter sawn I thought
Thanks for looking
Jon
Thanks for the interest
Got the other 2 carcases done today and have changed the design slightly from the one posted as I think it flows better
Made a slight mistake on one bit so will need to make a new panel
Just having a bit of a look to see what the wenge back will look like
Thanks for looking
Jon
edit- hopefully pics sorted
im making this for myself so have only made the bottom carcase today as i needed to do other jobs
I was toying with the idea of rosewood drawers but i think im gonna stick with the wenge although it would look nice
cheers
Jon
Got the units placed together to see how it looks
Going to start on the veneering next and hope it gets a little warmer soon so I can start spraying.
Jon
Jon,
Looking great. Did you consider making the vertical partitions in the bottom carcass double thickness to align with the top carcass? Not a criticism just curious as that's what I would probably do.
Regards,
DT
Hi DT i did consider it but wanted the grain of the wood to flow through on the bottom carcase .
Jon
It's pretty much still at the stage as shown in the last photos. Hope to get some time on it soon but have been very busy with other work
Jon
phil.p":292glqup said:
That first wenge looks like ABW, I've a kitchen full of wenge that doesn't look like that.
It's definitely wenge it does look a bit lighter in the pics though probably the fluorescent lights in the workshop
Jon
