I looked at that jig as I thought it might deliver some advantages for veneer cutting over my current set up, especially when used with some kind of stop block arrangement to get repeatably consistent veneer thicknesses, like for example this,
http://stockroomsupply.ca/shop/micromag-stop-block.html
However, I rejected it because it would mean the veneers would be bandsawn on
both faces.
Why is that a problem? Well, it's not a
terrible problem, but it's
enough of a problem that on balance it didn't seem a good idea for my applications. The way I cut veneers (in common with every cabinet maker I've ever met) is that after each slice the donor board gets passed through the planer/thicknesser, so each cut begins with a perfectly flat face, and finishes with one planed face and one bandsawn face.
Using this jig you'd end up with
two bandsawn faces, and the reality is that would reduce consistency and accuracy, plus it would involve additional work to subsequently flatten and smooth at least one face to make it glue ready, it's more work flattening a veneer than it is flattening a thick donor board. I'm sceptical that you could remove the donor board from the jig, plane it, and then replace it in the jig with absolute precision.
I'm not knocking the jig, I'm just pointing out some stuff that might not be immediately obvious to someone who hasn't cut veneers, but might be thinking this jig is a silver bullet solution.
