Luxcarp
New member
Hello all,
I have purchased a live edge walnut slab 52inch by 22inch, 2inch thick, it has been chemically dried, it was a little warped so I made a router planer jig which worked out perfect the slab is level/straight both sides, my concern is the man in the wood warehouse told me its dried to around 7per cent so if I want to make a coffee table out of it then i would need to cut down the middle of the slab, (along the grain) and joint it back together otherwise it will warp?
Is this correct? I am a little confused as I have seen other live edge slab coffee tables that have not been jointed.
