frugal
I mentioned in my jewellery box thread that I was going to a weekend course with Andrew Crawford. Well that was the weekend before last, and I have spent the last week and a bit finishing it in the evenings. The course was a birthday present from my wife and I was not sure what I was going to get out of it. The main things I came back with were: I use too much glue, a little thinned down PVA goes a long way; Andrew has exceptional levels of craftmanship and accuracy; disc sanders are a really usefull tool; I use too much glue; 0.1mm and 0.5 degrees are a lot when fitting mitred inlayed corners; he has a number of really simple really useful jigs; I really mean it about the glue; I really like making boxes and I loved evey minute of the course
The box we made up was from sides of solid walnut and a veneered walnut top and base. The sides were already machined up with the rebates and the grooves for the lid and base pre-cut. Our first task was to ensure that the lid and base were the right size for the sides, then we glued it all up, then sanded it to true it all up; then chamfered the top and bottom edges and routed out the recess for the inlay.
Fitting the inlay was very intricate work, but looking at the joints at the end of the day I was amazed at just how well it all went together.
As there was no time to put on the finish and line the boxes before we left we were given detailed instructions which seem to have paid off. The hinges are extruded brass which were polished before attaching and the lining is pigskin suede (Andrew gave us both the hinges and the lining as part of the course).
If anyone is interested in boxes I can whole heartedly recommend his course, even if you already think you know how to put a box together, there are just so many tricks and tips to learn.
The final box is 10.5" long, 8" wide and 2.75" high; lining is dark red pig suede and the finish is 3 coats of Chestnut Hard Wax Oil and a coat of clear Briwax to polish it up. As usual, all photos are links to Flickr if you want to see the larger size pictures.
![](https://proxy.imagearchive.com/82b/82bc878c6b6c36535ac21c21319a2276.jpg)
![](https://proxy.imagearchive.com/bff/bff72d3d67b417e463af70bd9091b9f5.jpg)
![](https://proxy.imagearchive.com/a24/a2406e2da492f9437d03e33659856f3a.jpg)
![](https://proxy.imagearchive.com/c14/c142e3a7b8c040b0f04971d219374996.jpg)
![](https://proxy.imagearchive.com/009/0090d3b8c400ccf9e987e2ec51baeabf.jpg)
![](https://proxy.imagearchive.com/ea2/ea22cf8ff9d4f16a29fc4a1fcf03075a.jpg)
![](https://proxy.imagearchive.com/394/394035bbbbab9fff4038f8e22d65950e.jpg)
