EddieJ
Just a quick update on this one as I haven't been on the forum for a while.
Sadly, I still haven't done the YouTube clip yet, but have to say that the tool has easily paid for itself time and time again. I can't find anything to fault with its operation, although I am going to have to upgrade my chip extraction for it.
The biggest surprise came when I finally managed to stop making the 100's of metres of 10mm air dried oak dowel, to produce the dowel that I actually wanted, which was 25mm air dried oak dowel. I had imagined that turning the larger section of wood was going to be more taxing on the drill and somehow harder to use. In fact it was so much easier and far less strain. It was also easier to remove from the tool. The smaller dowel seem to compress slightly, so removal can on the odd occasion be a pain. This is in no way a fault of the tool, but could be something that I am doing wrong.
Making larger section dowel also allowed me to use oak with the odd knot in, where as the smaller section oak had to be pretty much blemish free in every respect to prevent a resonance shear.
I rate this tool a straight ten out of ten.![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Edit.. With the smaller section of dowel, it is essential that guide blocks are used, but this isn't quite so critical on larger section material. I guess that the average dowel length has been 900mm in the smaller section material, and the longest in 25mm section was about 1,500mm. I didn't have the room to make it any longer!
![dscf0515k.jpg](https://proxy.imagearchive.com/27c/27cf05dbadcb6401fc0d47d1a3dca8af.jpg)
