wellywood
SWMBO wants me to refinish an old Singer machine table. The original had a swing-out machine which will be removed, the opening filled and the top refinished as a flat surface and re-veneered. Some of the existing veneer is lifting at the edges due to water damage at some time. The lifting only extends about 50 mm in from the edge and everywhere else the veneer seems firmly fixed.
I've only done one veneer project before so my question is, can I re-fix the lifting portions of the veneer then sand clean the whole surface and re-veneer over the top or should I bite the bullet and strip the old veneer completely? The picture shows the area on the extreme right where the veneer is lifting.
