Mrs C
Does anyone know what can be either mixed or applied over Van Dyke Crystals to give more warmth to the colour? What would have been the traditional method (if there was one)?
If your perception is that the applied dye creates a 'cold' colour mix other colours into the base Van Dyke (walnut) brown: red and yellow are two I've used many times to adjust the hue of the base colour making it warmer. With a bit of playing around with proportions of different dyes in the mix, plus sample boards, you should be able to achieve the desired colour in one application, which is one traditional approach. There are others, including application stages using different mediums to achieve required results, but I think I'll duck describing any of those options.Does anyone know what can be either mixed or applied over Van Dyke Crystals to give more warmth to the colour? What would have been the traditional method (if there was one)?
