oddsocks
Rather than hijack into another thread I've been reading (where a number of responses commented about 'must get the network extended to the workshop') I've started this one.....
There is technology often referred to as 'homeplug' that uses your mains cabling to extend the the network - a quick search on ebuyer revealed these 17 results and at the moment the cheapest option seems to be £53 for a working system (2 x the Zyxel)
http://www.ebuyer.com/search?limit=20&q=homeplug&sort=relevancy&page=1
This has two cabled devices - one is plugged into the mains and cat5 cabled to a port on your DSL router, the other end is plugged into the mains in the workshop (it has to be on the same phase) and cabled to your PC - you can obviously unplug that end and plug it in any other room in the house, or on the decking, conservatory etc as needed.
I personally have the netgear product WGXB102 in the link above for £81.95 - this has the fixed cable unit (near to the DSL router) and the other end is a wireless hub - great for laptops or putting on the landing etc. The wireless homeplug can be configured the same as your normal wireless router (with wpa and SSID etc), the laptop will quite happily detect the strongest of the two (from DSL router and homeplug- and will typically show an excellent connection.
With either fixed of wireless the homeplug technology works out of the box but can be configured with your own network key so that only like keyed devices can connect (just in case a neighbour on the same phase has similar devices). You can also use more than one (I think 12 is the limit) - so if you live in a mansion house or have an office in the garden as well as a workshop, multiple units can connect to the same unit plugged into the DSL. The results are much better than wireless (unless you are in the same room or very close to the DSL wirelsss router where they are equal).
There are a number of standards -11, 54, 80 and 200MBit/s. For internet browsing, forums etc any will be good enough and the lower speed would probably work in noisier environments. They are not recommended in commercial environments (where there are plenty of florescent tubes plugged into surge protected or UPS preotected points - Although I have tested mine in a surge protected extension and it worked fine.
