matthew
Phew, after what seems like forever, finally managed to get back in the workshop.
I'm taking a break from solid timber and making some storage units from 15mm birch ply, something like this:
Pretty simple stuff. They need to be quite strong - size is 800mm x avg 300mm (a few different sizes) and will be stacked 5 or 6 high (up to about 2m) and filled with books.
I'm not sure how to join the corners. The picture probably doesn't show this but I want the bevel the front edges inwards - this would be relatively straightforward if the corners were mitred, but I'm not sure if mitre & biscuits would be strong enough for the load?
Alternative is to butt them with biscuits - easier and stronger, and the sides won't really be showing anyway. But the front would look much nicer mitred and I can see the bevel being a bit awkward to achieve this way.
Any ideas much appreciated...
MTIA, Matthew
MTIA, Matthew
