My scroll saw came with useless, non pin end blade clamping devices. Basically the blade goes through a small hole in the device and then you have to try to clamp it between two allen screws. Obviously, when you turn one of the screws to tighten them, the blade twists and even snaps. I have filed the ends of the allen screws flat but it makes no difference, the blade still twists.
There is not a lot of room between the bottom location point for the adapter, plenty at the top.
I have looked all over the place to find a suitable clamp but so far have drawn a blank.
Can anybody suggest one please? The locating pin is 12mm wide.
