Howie1000
New member
Good morning all, I think I posted this in the wrong section earlier.
I’m part way through building my workshop/shed. It’s framed with 4x2, has cellotex insulation, 11mm OSB inside and out, then will be externally clad with featheredge.
I have a 3ftx4ft UPVC double glazed window and UPVC double glazed french doors to install, I’m not 100% sure of how to do it. I’m going to build the wood frame work for the door and window with a 5mm gap, but it’s the water proofing part that is stumping me. The window has a sill attached already.
Many thanks !
David.
Many thanks !
David.
