Undersized drills or reamers.
Munty Scruntfundle
22 Sep 2019
UK
Hi there.
I could really do with a set of undersized drills and or reamers for push fitting rods. I can't find these anywhere. Anyone out there could let me know where to go?
Many thanks.
TFrench
6 Jul 2015
Leics
What sort of sizes are you after? You can get most metric reamers in 0.01mm increments. Not cheap though!
AES
18 Feb 2011
Switzerland, near Basel
It largely depends on the size range/s you want. There are adjustable reamers but they're also rather expensive, and normally only cover a range of about +/- 2 mm. But they are fully adjustable to any dimension within the stated range, so if you only want "a few" diameters they COULD work out a bit cheaper than buying individual (single size) tools.
Personally, wherever possible I try to "design" any job of mine so that it uses one of (the few) existing reamers that I have.
hawkeyefxr
23 Jan 2017
hants
You don't say what size of reamer, below is a link to a chart that may help
http://www.toolingsolutions.com/technic ... _hole_size
Remember the first hole you drill a hole is just a hole to remove the majority of the metal, you then open up the hole to a size that a reamer can accept. The reamer removed just a tiny amount of material. Plus ideally it want to be done in a bench drill and the work not moved between the drilling stages and the reaming itself for best results.
This may sound convoluted but it is easy really.
TheTiddles
14 Oct 2007
Wiltshire
Are you certain you need a push-fit? Adhesives need a slight gap and if you have one anyway then you have a process that matches your tools
Aidan
