I presume this amp is analogue and feeding a number of televisions. Am I correct?
The Wolsey 4 Way Distribution Amp boosts the satellite signal in areas of poor reception, improving sound and picture quality. Distributes Sky to 2 TVs in the home without any noticeable signal degradation. Lightweight compact design - can be powered either from RF2 digibox output or separate 9V DC power supply, making it ideal for placement in lofts Individual short circuit protection - should a short circuit occur on one port, individual short circuit protection will continue to operate the other ports & will not shut down the whole amplifier Integrated digital bypass - ready for use with the SKY, digieye extender feature, allowing the digibox to be controlled from a second location Double insulated safety certificated to the latest BS and CE standards (EN5008-1, EN50082-1, EN50083-2 & EN61000-3-2/-3) Class-leading noise figures of 5dB for minimal interference Full instructions This unit has F type connections. 12 months full guarantee.
DaveyP":2zqgon3x said:I presume this amp is analogue and feeding a number of televisions. Am I correct?
its a bi directional distribution amp
Woody2Shoes":zkjzeudr said:From doing a bit of Googling (I don't have Sky) this kit will allow Sky TV to be distributed around the house (along with Freeview and/or radio from a conventional antenna). The the bi-directional bit is to allow a "Sky eye" type of IR receiver device to transmit handset commands back from a remote telly, via the amp, to the Sky box to change channels. The amp can take its 9V power supply from the Sky box, obviating a wall-wart in the loft. Cheers, W2S
