whybob71
Hi all,
from fews weeks the scheppach TS2500ci is in my lab . I like the machine, but I have some questions.....
1) The (phenolic?) two-pieces insert in the table seems to be not 100% flat when mounted on the table top, even if is flush with it. These make difficult to me to square the blade with the table top. I tried to adjust it by moving the four screws but I'm not happy with the result. Finally I adjusted the squareness of the blade by removing the insert and by using a 6" good square. Even so, I'm not confident with what I did......... :?
2) I would like to buy the 200 mm adjustable grooving cutter (or trying to fit the 200 mm CMT dado blade): do I also need the table insert and collar nut?
many thanks
Roberto
many thanks
Roberto
