Maverick81
Has anyone checked out the Triton Dowel Jointer? Here is a video showing the machine in use....for anyone interested.
https://youtu.be/Tvfg1_aH0kA
marcros":24lw1sex said:related question- I have a lathe bench to make, and was going to use 3x3 softwood to do so. 4 legs, 4 stiles, 2 top rails, 1 bottom rail etc
I dont have the big domino, so that is ruled out. Would something like an 18mm dowel or pair of dowels be sufficiently strong to join the frame? It would be much quicker than cutting mortise and tenon joints if so and is effectively a loose tenon system by another name. I should be able to cut the pieces, clamp the joint, drill it and insert the dowel as a through tenon.
There is a dust extraction port, apparently - he just didn't use it :roll: Don't know if he was using particularly blunt cutters, but it seemed to take a lot of effort to drill the holes :/Blister":1xc8o51a said:Zero dust extraction options and in the video he was covered in dust , I'll pass
