They're back - but only in 5s for £20 item No. 272096781370
I tell a lie, £5 each - 272096781378 (further down the page - I didn't see them )
phil.p":3jyio7s3 said:I presume everyone that wanted these has got them by now?
phil.p":162wampm said:I presume everyone that wanted these has got them by now?
phil.p":37y2kkoq said:If you'd seen the other threads on this, you'd know. It will knock out from underneath - I suspect there was a flaw on the fine side which led them to be stuck in reduced in price and sold as single sided. There will be stuff stuck to perimeter of the fine side but it will be usable.
phil.p":2j5ov751 said:Good idea - I'll try that on my other one.
Normancb":2ficxndd said:Depends on the glue but if it's the standard EVA hot melt it will be in the range 50 - 100 C - somewhere around 80 C is common
Very much depends on the polymer they used. There are hot glues with a low melting, popular for craft work so you won't scorch your skin if you accidentally get some on your fingers, and others melt well above 100°C.bugbear":1gosatye said:Anyone know the melting point of hot glue?
Aden30mm":2x98je4p said:. Knowing the areas where the glue is next time I shall just heat the corner areas, maybe allowing the area to cool and then apply heat.
See the freed stone and glue witness areas on the smooth side.
A fiver for two stone surfaces got to be the bargain of the year.
Rgs
Aden
