Benchwayze
This is going to be so difficult to explain, but I'll do my best, so someone might be able to put me right.
From my surfing, looking at various track-saws, I get the message that if you lay the track-rail down, dead on the line, it's impossible to end up with inaccurate pieces; no need to take into account the thickness of the blade. I can't see this. The kerf must be factored in, surely?
Suppose I want to cut two pieces of ply, two feet square, from a sheet, six feet by two feet:
My usual practice is to work from right to left. So I cut a two foot length, from a six foot length, leaving a four foot length to my left. (I.e, four feet, minus the kerf width)
I would then cut another two foot length from that, leaving a piece of waste, under my guide. This 'waste' would be two feet by two feet/minus the kerf width. (I could probably use that for another job!)
So, working as I usually do, if I put the track-rail down on the line, with the workpiece I want to the right, I am surely going to end up with a piece which is less than two feet long; by the thickness of the saw-blade. Is it just my visualisation, or do I have to work with the waste to the right? In other words, with the track-rail positioned on the piece I want, rather than on the waste?
It's driving me ape!
I see the point of a track saw, but I think it is going to force me to work 'left-handed'. In other words I will have the piece I want to keep under the track rail, with the waste to my right. This is likely to lead me to an accident waiting to happen, or cutting errors galore. As I said, it's driving me nuts and I am wondering if I should just stick with an MDF guide, and offset my saw, by the distance from blade to base-edge. Using this method, the pieces that come off the saw are the pieces I want and are dead to size.
Or am I missing something? :?
Thanks in Anticipation.
