A
Anonymous
Guest
Hi all
Another tip I have for cheap and useful tools. I wanted a height guage for setting tablesaw and router table + measuring project components against a flat surface. They cost a fair bit as you can see here
http://www.axminster.co.uk/default.asp?part=CM192106
So, I made my own. I nipped to B&Q and got a cheap combination square for about £6 and made an oak base. I cut a slot in the base the same width as the ruler section of the combination set and drilled a 5mm hole through the wood. I opened the hole to 6mm on one side of the cut and tapped the other to 6mm. Push the ruler into the slot and clamp with a bolt.
I decided to cut the extraneous bits of metal off the guauge to keep it small.
Works very well and I am chuffed with my bargain basement height guage
I guess you could leave the guage whole and remove from base for 'normal' use but I decided to keep my expensive combination set sepperate from the height guage.
Tony
Tony
