Timber and finish for bathroom furniture
Garden Shed Projects
21 Apr 2021
Northamptonshire
A few years ago I lived in a flat that had built in wall cupboard in the bathroom. It was definitely made of timber, probably a Vaneer not solid. It had a reddish finish which could easily have been in the finish. The flat was new maybe 15 years ago so it was definitely new material it was made from.
I am looking to build something similar. I realise the description above is pretty vague but was looking for timber or material that would work in this application. Initially looking for the timber look but am also considering mdf sprayed, would that be ok in a damp environment?
Any thoughts greatfully received.
Thanks.
MARK.B.
4 Jul 2012
East Yorkshire
I would avoid using MDF in a bathroom if at all possible, even the moisture resistant stuff :)
gog64
19 May 2018
herefordshire
I’ve used MR MDF in bathrooms for custom bath panels and cabinets. Painted properly. Never had a problem.
Bristol_Rob
18 Jul 2018
Bristol
Compact Grade Laminate (CGL) panels
These are the resin products used in wet rooms - impervious to rot etc ;)
21 Apr 2021
Northamptonshire
I use this stuff on site all the time and it has an institutional feel to me. It’s good gear. I am looking for something a bit more modern and slick.
What material is this made from? You see stuff like this in hotels and high end bathrooms.
21 Apr 2021
Northamptonshire
This is a photo of a bathroom in the development I used to live in. Got it off Google images. It’s not a great photo but maybe you can zoom in to the vanity a little.
Bristol_Rob
18 Jul 2018
Bristol
I call them resin products.
Mutley Racers
15 Jun 2017
Molesey
Keeping an eye on this thread as I want to build some cabinets like you say. Struggling to find a material. I actually wanted to do some concealed cabinets with tiled doors but there is no product that you can fix tiles onto that is suitable for tiling and will be strong enough to take a hinge.
Bristol_Rob
18 Jul 2018
Bristol
No. The mirrored unit in the photo was some kind of veneered timber.
Maybe it's just that. A moisture resistant ply with a simple wood veneer glued using a waterproof glue and then varnished.
After all, there are plenty of timber boats utilising similar techniques.
I'd cast your research net towards boat builders
Just be prepared for high maintenance to keep such products in these environments tip top.
glenfield2
2 Nov 2018
Suffolk
Me too for bath and wall panels. Painted it’s fine. I wouldn’t use it to line inside a shower cabinet with though :)
Seems to me the stuff gets a bad press - certainly in the canal boat game builders avoid it then happily use plywood or softwood. TBH if any of them are likely to be continuously immersed in water the boat’s probably sunk!
Bristol_Rob
18 Jul 2018
Bristol
My bathroom floor is 18mm mdf MR
I have 2 kids that have sloshed more water on it than I care to remember.
It has stayed intact and not disintegrated.
Kid proof 🙄
