Shadowfax
Anyone got any tips for removing tiles from a kitchen wall that is dry-lined? The last time I did this it wrecked the wall lining. I am actually tempted to tile over the original tiles.
Help!
SF
Help!
SF
tiler99":1t5nab41 said:Its all down to the prep. Better the starting surface is, the better the finish and quicker.
Its false info when they say you can use more adhesive to build the walls out when fixing tiles. It makes for weak walls and problems in the future.
My advice if you could do it is to remove the tiles and board. and replace. Its not that hard to do. A bit of common sense is all thats needed.
tiler99":1t5nab41 said:While you remove the boards is a good chance to centralise sockets etc.
