three legged table
jonw1664
19 Jul 2019
Trowbridge
I want to try to build a set of three legs that cross and then support a table, I know it doesn't come across very well in words. If you look at the attcahed photo it shows a metal clamp that would achieve the same thing with metal tubes but I am keen to try and build the whole thing rather more elegantly in wood. I also don't want the angles to be so wide that I end up having to have an enormous top to get to the right height! I assume that there is some sort of name for this type of joint that might let me research a drawing of how it could be made but so far I haven't turned up anything, does anyone have any knowledge/bright ideas etc that would set me on the right path?
Jon
AndyT
24 Jul 2007
Bristol
This blog post from Chris Schwarz is actually about making three legged stools, but it describes approaches to the joint where the legs meet. I know your table won't necessarily need to fold, but it (and the linked to article) might help visualise one solution.
https://www.popularwoodworking.com/wood ... ng-stools/
There must be something more elegant, like a three way lap joint, but not flat.
