TrimTheKing
Hi all
I have had a long standing bugbear with my PT (Axminster 106PT2) in that I was sure it was thicknessing in a wedge (thicker on one side than the other across the table width). I got 20 mins to test it this evening and wanted to see if I am being too picky or if there is something I can do to rectify it.
Here's my quandary, I took a 2' long lump of 40mm beech and:
- Planed it flat (I have already taken time to set up the tables to make sure they are flat/coplanar etc).
- Next I flipped to thicknesser mode and ran it through until it got rid of the small amount of concavity.
- Next I get out the digi caliper to check, and here's what I found...
Imagine the board is fed through and you are looking at it from behind as it is going through, the corner you can see on the left is corner A, the corner in front (along the long edge) is corner B, the corner closest on the right is corner C and in front of that corner D.
My measurements were as follows:
A = 1.500" (38.10mm)
B = 1.493" (38.03mm)
C = 1.479" (37.58mm)
D = 1.482" (37.65mm)
So it looks like it is around 0.5mm out (thicknessing thinner on the right side of the table). My questions are:
- Is this acceptable to you out there?
- Can I fix it? (I think the blades must be out by half a mil on that side of the table, or can the thicknessing bed be moved?)
- Am I being an pineapple and this is perfectly normal and acceptable???
Mark
Mark
