The Veritas Shooting Plane
Derek Cohen (Perth Oz)
2 Mar 2005
Perth, Australia
As promised, once Rob and Co released their brand spanking new shooting plane, I have published a review of the plane for your entertainment and education :)
The website link is here: http://www.inthewoodshop.com/ToolReview ... Plane.html
Feel free to ask any questions.
Regards from Perth
Derek
Nice review thinking about getting a shooting plane I was fitting oak architraves yesterday and just seems to be with oak the mitries are of at the heal and the toe tight in the middle do you just make a shooting board for the mitres
Nice review Derek. *AND* you appear to have demonstrated fairly conclusively that there's more to blade quality than the steel composition.
BugBear
Hi guys am I being daft but I can't seem to find affordable shooting planes lie nelson at 430 just way to much for me till I win the lotto
Cheers for the help sorry if I am hijacking the post
Hello,
Excellent review Derek, thanks.
Regarding affordable shooting panes, the Veritas should retail for a fair amount less than the LN, if prices from the USA are anything to go by, but not enough to make it 'affordable'. There are none that are though, new. The best metal plane that won't break the bank would be a second hand Record T5, with, referencing the blade tests in the article here, a replacement LV, A2 or PM blade.
Mike.
The LN blades began dulling after about 30 shavings, at which point they increasingly were required to take more passes to complete a full shaving – instead of cleanly slicing the end grain, they skipped and left untouched sections.
By contrast, the Veritas blades were still sharp at the end of 60 shavings, and could have gone on planing for much longer. Of the two blades, the A2 began to feel a little more difficult to push at about the 55 shaving mark, but continued to the end of its 60 without skipping a beat.
Interesting. I recall a thread a year or so ago, where mtr1 had problems with edge retention on a L-N A2 iron.
It seems that Lie-Nielsen are not doing something quite right - which is a pity as IMHO Lie-Nielsen tools are the best of the top three. Certainly their back-up was top-notch in mtr1's case.
Cheers, Vann.
For many purposes, a "normal" plane will work "well enough" - my personal favourite is a #6.
If you want the oh-so-desirable benefits of a skew blade, the cheapest way is a Philly mitre plane.
http://www.phillyplanes.co.uk/skew.html
BugBear
It's OK don't worry about it nobody really needs them anyway - they are just toys for the comfortably off!
iNewbie":3vm8iqvs said:
Bit like a Sorby Pro-edge, eh?
Bit of Wet 'n' Dry 'll do for grinding. Freehand of course.
Hmm stretching it a bit! Sorby Proedge (or similar) is an extremely useful bit of kit and would get well used in most workshops.
These planes aren't and wouldn't.
Maybe not in your workshop, Jacob, but then you seem to spend all day on your computer rather than doing anything which would require a plane.
Cheers :wink:
Paul
I was pleased to see that Veritas are to produce a leftie version due out in October :D
Hello Derek, unless I missed it, would you tell me the maximum thickness (height) that the Veritas can plane when it is in the Stanley shooting board, how much of the blade is usable?
Mark if Derek doesn't respond I have the shooter but not the board but I can measure from the sole up the blade and then if you have a chutebored you can measure that depth.
