Jacob
New Luddism. Awake and resist!
The Cutting Edges of H.O. Studley
Interesting article. Schwarzy concludes that Studley would say as follows:
1. I like a convex bevel. Nearly all of the edges I observed had a slightly convex bevel. A couple tools had evidence of a hollow grind in the middle that was in the process of being removed by sharpening the bevel (making it convex).
2. I like cambered edges on my planes. Nearly every edge of the plane blades (blocks, smoothers, jacks and try) had a cambered cutting edge. Many of the edges were significantly relieved at the corners.
3. I sharpen the entire bevel. Only one tool had any evidence of a micro-bevel.
4. I lap the backs of my irons and chisels. All of the tools in the chest have lapped backs. The lapping is not to a mirror sheen, but there is evidence of significant and continuous work on the backs.
5. I lift my plane irons slightly when I polish the backs. Over and over I saw evidence that the very tip of the back was polished to a higher degree than the metal behind the tip. And (using a machinist straightedge) I could see that the tip of the back was ever-so-slightly dubbed from this polishing. The polishing on the backs was heavier on the bevel-up planes than on the bevel-down planes.
You can take the above information and twist it however you like. Studley was a hand-sharpener. He sharpened the entire bevel. He did something similar to the ruler trick – though he probably didn’t use a ruler. He knew that he needed two intersecting surfaces to create a sharp and durable edge.
