Few people are capable of expressing with equanimity opinions which differ from the prejudices of their social environment. Most people are even incapable of forming such opinions. A. E. 8)
bosshogg":3fbu5tub said:A photo of the jig it's self would be nice. Also you mention doing various wood shows, were you a sales rep? and what went so horribly wrong for such a vow of abstinence??...bosshoggFew people are capable of expressing with equanimity opinions which differ from the prejudices of their social environment. Most people are even incapable of forming such opinions. A. E. 8)
Templatetom":3sg67m4t said:I will submit the photo of the Jig soon
9fingers":2rerfu4m said:I use this for all my tenons
http://www.amazon.com/Delta-34-183-DELT ... B00004TD3O
Numerous clones available in UK
Just add FTG tooth saw blade in the table saw and away you go.
Easy to set up and use, safe as both hands are behind the jig.
Repeatable and accurate.
Bob
9fingers":36kevisa said:Roger,
The jig itself is designed with handles placed such that no further guarding is really necessary. Both hands are to the left of the blade and so the body naturally is also out of line with the blade.
I've not had any problem with 'stock waving about'. The clamp is pretty positive. Obviously the distance from the table to the ceiling is a limiting factor but not one that has affected me yet.
This photo is from an earlier project. The F clamp is holding a sacrificial piece to reduce breakout. The main jig clamp seen on the left hold the workpiece.
Bob
9fingers":3n0amvt2 said:.....
NB despite my user name, I do have 10 fingers
Bob
bosshogg":2auayxpn said:A photo of the jig it's self would be nice. Also you mention doing various wood shows, were you a sales rep? and what went so horribly wrong for such a vow of abstinence??...bosshoggFew people are capable of expressing with equanimity opinions which differ from the prejudices of their social environment. Most people are even incapable of forming such opinions. A. E. 8)
Same here for sawing tenons, correctly set up a band saw is almost fool proof. Mortises I do with a router as well but now I have the Domino :-" (Mk1 version)...who knows? - RobBenchwayze":27swsiy6 said:But then I bought a bandsaw, and for machine cutting that is now my preferred method. It's the safest way I know. The blade is always completely guarded or buried in the stock and the worst that could happen is for me to forget to put a stop block beyond the blade and saw straight through with my fingers in line with the blade. So far so good.
I do use a hand-held router with an upcut spiral bit for morticing, but that's when I need to mortice into end grain too, when making a slip tenon. A method I have used since the Domino made such an impression on us.
woodbloke":282lkllu said:Same here for sawing tenons, correctly set up a band saw is almost fool proof. Mortises I do with a router as well but now I have the Domino :-" (Mk1 version)...who knows? - RobBenchwayze":282lkllu said:But then I bought a bandsaw, and for machine cutting that is now my preferred method. It's the safest way I know. The blade is always completely guarded or buried in the stock and the worst that could happen is for me to forget to put a stop block beyond the blade and saw straight through with my fingers in line with the blade. So far so good.
