Hi folks.
I’ve got to make a little table up out of solid Ash for inside a yacht as per pic.
Its 900 long x 580 at one end and 220 (all mm) at the other and 30mm thick.
One long side has a slight radius on it.
So my thinking was to lay out the wood in a triangle so as to avoid lots of end grain on the radius showing up but now I’m thinking that if this swells at the back along the widest section it will pull the front apart.
The wood is Ash and at 11% mc. My thinking is the boat is unheated and quite damp so there's going to be quite a bit of movement.
Any thoughts?
Regards
Glynn.
Any thoughts?
Regards
Glynn.
