T Track and accessories
Charlie Woody
10 Dec 2010
West Devon
I recently purchased some T track from Axi http://www.axminster.co.uk/axminster-ax ... rod840636/ along with a couple of Kreg Track Clamps http://www.axminster.co.uk/kreg-kreg-tr ... rod789552/.
I already had some of Axi Star Knobs http://www.axminster.co.uk/axminster-ax ... rod864186/ and was hoping that I could use the star knobs with some M6 hex head bolts in the t track. Alas not :( The M6 will slide into the track but will not tighten up .... the heads can turn in the track. M8 bolts are too big!
The Kreg track clamp has a hex head which is a perfect fit. I think that Rutlands sell the imperial bolts but they are kinds expensive!
Does anybody know of a cheaper solution please?
The solution to your problem lies here. The sliding 'T' bolts will fit the Ax track, but the threads are 'murrican, so Whitworth or equivalent. Metric knobs won't fit on the threads...annoying, but just use the ones in the set - Rob
Thanks Rob
I had seen this but I only need about 6 bolts and knobs so was reluctant to spend £36 on stuff I may never use. Wo
Wonder if anybody still sells imperial hex bolts and threaded inserts from which I could make my own knobs?
Hi Bob
I had considered that ...... but decided against it as I think I would have to file the "top" of the M8 hexagon too. Just too much filing for my liking!
I use roofing bolts to make my Tee bolts. A couple of quid from the likes of Toolstation for a pack of 25. Buy the longer sizes and just cut them to length. Not much filing either.
Oz
+1 for roofing bolts.
I think the square part of the shank fits the narrow part of the T-track too. Yes, you do need to file or grind them, but it really only takes seconds on a grinder, and they're very cheap.
I use them for quite a lot of jig applications, and the M6 and M8 ones for concealed adjustable feet on furniture, as our floors are far from flat.
E.
