wizer
- Joined
- 3 Mar 2005
- Messages
- 15,589
- Reaction score
- 1
Following on from Miles' post a while back. This is one of my loose ends that never got tied before the op, that never happened (confused?).
I decided to chop up the 6inch board today
It was 6ft long 21inches wide and 6 inches thick. It's now cut into bowl blanks (yes, bowl blanks).
However, I noticed that it's got some heavy staining right through the board. Noticeable on the cut edges:
Thes rest of these boards are to be used for bedroom furniture in the new year (probably mid spring now) and I'm a bit concerned about them. The intention is for them to be stained or painted black, so the staining is not so much of a problem. But I'm a bit concerned that they may continue to spalt or rot in their current location
At the moment they are not in stick and, at over 13 foot, they are too long to be stored upright anywhere.
So the question is this. Will they remain stable over the winter under the tarps on my concrete (sloping) drive? They are up on 28mm hardwood blocks to let the water run under them.
Or should I cut them into manageable pieces and store them in my garden shed? To do this, they'd have ot be cut down to something like 5-6ft.
My concern with that is the old addage "Keep is as long as possible for as long as possible". That said, none of the furniture it's intended for will need a part more than 4.5-5ft.
Comments Views?
oh and if anyone has a spare hand, my buttocks needs wiping :shock: :lol:
Comments Views?
