Hi Paul,
We use a rubber roller, about 4" wide, with a long handle that we can get two hands on for maximum pressure. The idea is to get a good amount of pressure all over the board. When I first started I remember just using a cloth and pushing very hard with our hands, not sure how successful this was in getting a strong bond though, a roller is much better.
Oh, and to get a really good edge, would you leave a small overhang on the top surface then fit the edge (providing it has a perfect stright edge) before trimming the top? ... or is that asking for trouble?
Yes that would be difficult. When sticking the edge, especially if you are going right round the piece, cut it plenty wide enough and make sure that you start very square as it is very difficult to correct it if it starts to run out. Once it is stuck it usually breaks rather than coming apart again.
I would glue the bottom on first, trim that flush with the edge. Glue the edge strip on second and trim that flush with the top. Then glue the top face on last.
It is practically impossible to mitre the edge as it would be too difficult to position the top face in the correct position once the glue is on. As soon as the two faces make contact they start to stick together and do not want to come apart. This is the reason we make the top about 2" larger than needed all round as it gives space for aligning, 2" gives us enough space to get it wrong now and again, especially on large sheets.
You have to put up with the edge looking a different colour, or at least I've never seen anything else. If you finish the top corner square, as opposed to 45 deg and then file the top corner lightly, to remove the sharp edge, then the brown colour difference is less noticeable. The solid colour stuff is marketed on it's scratch hiding ability, never used it so no idea what it is like. Also the gloss products show the scratches much more than the more matt surfaces. Make sure that you leave the plastic cover on until you have finished otherwise the router will mark it.
Wealden Tools do special laminate trimmers which we find best for the 45 deg
http://www.wealdentool.com/acatalog/Onl ... e_276.html the easy trim angle ones don't work as the bearing runs in the wrong place, I've tried it :roll: But the for the straight ones we use
http://www.wealdentool.com/acatalog/Onl ... m_267.html part T8123B
I bought the trimmer at the same time as I built the kitchen about 30 years ago
, and I've never seen it sold since. Its a bit like a veneer edge trimmer with a tungsten carbide cutter.
I guess with the router cutters available now they make it easier, but very messy!
Sorry, long post again, I'm a detail man
but it keeps the quality up :lol:
Hope it all makes sense.
Johnny B
