Supernova Standard Z Chuck
Vic Perrin
10 Mar 2013
Rugeley Staffs
Hi all, Hope you engineering experts can help with this one. I have a Supernova Standard Z chuck which if fitted with a insert that takes it down to fit a 3/4 x 16 tpi drive.
I have removed the insert but the thread is too big to fit the drive on my Record Maxi 1 which is 1 1/4 x 8 tpi.
There is a part listed on Record Webb site but this is for the Supernova 2 chuck and although the internal thread will definitely fit my maxi lathe I do not know if the external thread will fit into the Supernova standard Z.
Hope this males sense ?
:?: Vic :?:
Hi
I've never heard of a type z chuck, are you sure it's not a typo for Supernova 2?
All I can suggest is you get in touch with Record Power through their website - you'll get a response within 24 hours in my experience.
Regards Mick
Spindle":2f6zppth said:
Hi
Regards Mick
Hi Mick, it is the Supernova Geared chuck the one before the Supernova 2 came out.
I have put a request in to Record Power via their web site as you suggested.
Looking at the Tecknatool info I think the inserts are available
Vic
    184.3 KB
Hi Vic
I have a couple of those chucks - if you don't get a satisfactory response from RP I'll remove the insert from one of mine and measure it for you.
Regards Mick
Spindle":1lpq54f0 said:
Hi Vic
Regards Mick
Cheers Mick your a star
Regards
Vic
That looks identical to the chuck I bought second hand that was described as a Supernova 2. I've bought two inserts for it that were variously described as for Technatool or Robert Sorby. One was a chuck insert 7/8 x12tpi Left hand thread (for the outboard of a Myford ML8) from Turner's Cabin and it has worked fine. I'd be very surprised if a manufacturer that changes so little in the overall design would change the tooling on the insert thread.
Good luck!
Steve
Got sorted with an insert for the Chuck from Record Power.
I now have an Insert for the Supernova to 3/4" x 16 tpi going cheap if anyone wants one
Thanks for your help
Vic
