Stuck toolpost
Chucky
New member
19 Mar 2020
Hello, I recently bought a myford ml7 that I am refurbishing, I've found that the tool post bolt just turns with the stud and on removing the slide I can see the the bottom part of the stud is also rotating. Does anyone have any ideas on how this could be removed?
Myfordman
AKA 9Fingers
19 Jan 2013
Southampton area
drill a small hole from under the slide somewhere on the circle between the end of the toolpost stud and the topslide casting.
Insert the shank of the drill into that hole and unscrew the toolpost nut.
TFrench
6 Jul 2015
Leics
Can you push an allen key or something into the T-slot to jam the nut from spinning? Or is it round?
TFrench
6 Jul 2015
Leics
Sorry Bob, I bow to your superior knowledge!
Sent from my SM-G973F using Tapatalk
