Storme sharpening jig - marking?
drillbit
19 Jan 2011
I replaced my home made wooden sharpening jig with a more robust storme jig from Axminster which is much better. However one advantage my wooden version had was that I could pencil in lines on the arm to show where I ground each tool, which meant a) hardly removing any material on each grind and b) not having to wait for the grinder to stop before sharpening the next tool.
Dies anyone have a trick for this on their own metal jig? Pencil doesn't seem to take and masking tape is no good because it fouls the movement of the arm in it's housing.
Any suggestions?
I have used the point of a set of callipers and scored a line around the bar where it goes into the holder but only after I have made sure I am happy with the grind.
If you want to change it later just go over the line with a permanent marker.
john
