CroppyBoy1798
Hi guys,
I picked up a pretty decent c.late 70's early 80's Startrite Tilt Arbor 12" table saw, a few years back it was converted to single phase and has a 2.2KW (2HP) Brook Crompton motor fitted.
Saw is running fine after having the starter fixed however I'm noticing intermittent vibrations when the saw is turned on and the bracket that the motor is attached to seems to vibrate somewhat (more than it really should I imagine), you can almost time the vibrating moments, its like 'smooth......vibrate......smooth......vibrate', almost a shudder perhaps. All the bolts are tightened on the motor and bracket are secure and nothing appears to be worn or have any play in it (pivoting points etc).
Now, I havent got the saw bolted to the floor, but I dont think thats the issue, the saw itself is solid and not rocking, the vibration is emminating from the motor/raise/angle mech area and is confined to this area (but obviously I can feel it through the table and see it on the blade/riving knife..
What I've noticed is that the belts to be used in the saw are 7mX800's, the belts in the saw are 10X800's, could this be the root of the problem??
Thanks for any info/help! :wink:
