I was lucky enough to pick up this bandsaw from facebook marketplace but i need a bit of help with it and have a number of questions.
All of the photos are here: https://imgur.com/a/6e751PW
First and most important, i am not sure the blade guide is all there. What is there slides and turns well etc but i was expecting a bearing or something similar to support the back of the blade. It appears to have worn its way into the sliding block behind and i doubt that is normal.
*edit* the piece i am holding in the photo was found under the bandsaw when i collected. Owner said he didnt know what it was from and i took it just i case. Could be a red herring.
My second question is does anyone know exactly what this bandsaw actually is? I saw a very similar one posted a couple of years ago talking about this being an import from italy that was then badged here. Theirs was part of 'a-range' from startrite. The serial number of this is B355 so im wondering if this is b-range?
As you can see from the photos the wheels say startrite and the startet switch is cast with 'made in england' on it. The motor is also a brook crompton so all of this would have had to be added to the italian import? Or this was actually made by startrite?
It is largely in excellent condition and all i really want to do is give it an oily rag, set up the blade correctly and go to work. I dont want the blade guide to be unsafe or incomplete etc.
Lastly someone has re-wired the switch to have a long blue flex cable on it. They have earthed this to the outside of the switch casing which seems ok, however they haven't done anything with the earth coming from the motor. Where would this be best earthed?
Thank you for any help you can give.
![RJrJK91.jpg](https://proxy.imagearchive.com/e73/e73b758986fa0b89e28208de64e3c890.jpg)
![BRPmBLW.jpg](https://proxy.imagearchive.com/3cf/3cf40b9f3d5bd3cd366ea88e803c48f4.jpg)
