Lurker,
I expect that I would be in trouble if I posted a copy of the design in the book as Taunton Press, the author or both will have copyright. However, I think I can describe how it works. Apologies for how long this post has become.
I didn’t know that commercial blade tension meters are available until I read the article by John White in the book mentioned above. Here is an example
http://www.toolcenter.com/62126.html
The principal of operation is to measure the distance between two known points when the blade is pulled into shape but with little tension and then between the same points again when tensioned.
Robert Hooke sussed out elasticity and the relationship between stress and strain in the 17th century. Google “Hookes Law” for details.
Apparently a 5” length of blade stretches 0.001” for each 6,000psi of tension that is applied.
The commercial instrument indicates tension directly on the dial.
The DIY model works the other way, you make a sliding gauge in 2 parts with positions to clamp the gauge to the blade 5” apart when closed. The gauge is clamped to the blade after taking up just enough slack to pull it straight between the measuring points. Clamp to the flat part of the blade behind the teeth.
If the gauge has a small known gap at the start the stress applied can be measured by re-measuring the gap after tightening the blade. Applying 15,000psi (the stress) would stretch the blade 0.0025” (the strain) and the gap would increase by this amount.
15,000 / 6,000= 2.5 times 0.001” which is 0.0025” or 2.5 thousandth of an inch
The change in the gap can be measured using feeler gauges.
In the article the body of the gauge was made of a piece of hardwood 5 3/8” long cut into two parts and joined to slide on a steel pin made from a nail. The second nail was used to form part of the gap into which the feeler gauge is inserted. Many imperial feeler gauge sets have a very limited range of blades of thickness in 0.0005” (half thou) steps. If a suitable screw were substituted for the second nail it could be used to adjust the initial gap to suit the feeler gauges available.
The saw should be warmed up before using the gauge to check the tension because blade and tyres will expand as they warm in use. The article suggests the DIY gauge read within 10 to 15% of the readings obtained using a commercial gauge.
Whilst writing this it occurred to me that, if it is possible to fit a cheap digital caliper in the gap between saw table and top guides (or take the measurement on the other leg of the blade), it would be easy to modify the caliper do this job. Drill and tap a hole in each of the jaws of the caliper to allow fitting of a pinch screw. Put washers between the caliper jaw and the screw head to offset the tool enough to avoid the set of the blade Turn the caliper on and set it to 5” gap*. Clamp to the blade with the pinch screws. Press the zero button. Tighten the blade until the caliper indicates 0.0025 inches.
* Actual reading should be whatever gives 5” between the clamping points.
The distance used for measuring should, within reason, be as large as conveniently accommodated on the saw you have and the numbers adjusted accordingly. So if the measuring distance were 6” then 15,000 psi tension or stress would give 3 thou strain or elongation.
Hope that makes sense!
Graham
